Endurance MakeBlock engraving/cutting machine
Endurance Robots
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
General features:
Aluminum extrusion parts.
Two Metal stepper motor with back shaft.
12V Solenoid include.
Closed type bushing block and ball bushing insert for use in linear motion applications.
Four-bolt aluminum alloy bushing block for a lightweight ready-to-mount installation.
Synthetic resin retainer plate for accurate ball guidance and low noise.
Four rows of recirculating balls inside the ball bushing for smooth running.
Integral lip seals to retain lubricant and protect against contamination.
Round steel shaft for use with slide units in linear motion applications.
Chrome plated for corrosion resistance.
Case hardened for wear resistance.
Precision ground for consistent ball bushing radial clearance.
Software
The fool information you can find here:
http://endurancerobots.com/products/endurance-makeblock-engravingcutting-machine/
Video:
