Bug squashing
A project log for Gcode Manipulator
Why G53 zero your CNC machine when you could just MOVE YOUR CODE to the origin!
AndyAndy 04/22/2016 at 02:470 Comments
I was about to write about the re-write I just did, except before I published, I decided to do one last check to make sure it was really working. Good thing I did, because it was not working. I'll write the rest once I get the chance and the energy, but the gist is, RS274 got split into several classes and structs and is now fully multithreading capable. As in, if you feed it a 35MB text file, it will saturate your system resources until it's done. It's great, memory consumption is approximately linear!
