Great news and a big design change
A project log for Classroom music teaching aid
An interactive device for helping a kindergarten class learn to play harmonica.
shlonkinshlonkin 03/30/2016 at 12:290 Comments
This project won the Pi Zero contest! I still don't have a Pi Zero, but the reward from the contest is going straight back into this project. I used some of the gift card money to buy a teensy3.2 with the audio+SD adapter board.
I've been really conflicted about using the Teensy+audio board because it feels like cheating. I actually breadboarded the audio circuitry and was in the process of debugging the audio input and frequency detection code for Arduino. Then I won the contest, discovered the audio board for the teensy and decided to change everything. Even though the arduino solution is vastly more complex, requires a lot more work, and gives much worse results, there is something more satisfying about designing and making it myself.
But anyway, this gives me a big step forward and I eagerly await the package. In the meantime, here is a list of the changes. They will be reflected in the description and parts list as well.
Here is a simple diagram of the electronics
Now I'm off to delve into the teensy audio library to learn how to program this thing.
