Two more changes for the next rev
A project log for FTDI-be-gone
My version of the ubiquitous USB serial port gizmo
Nick SayerNick Sayer 02/27/2016 at 07:390 Comments
The current version works fine electrically, but some of the silkscreen wound up on the wrong layer, so I've fixed that. Another minor issue is that the GPIO I chose to use for the !FORCEOFF line is defined as !SLEEP, but there's another called !POWER that's a slightly better choice. Lastly, the 10 uF cap is just a little too close to the USB connector for comfort, so it has to move just a touch North.
Other than that, the design is perfect, and the next step is designing the 3D printed enclosure for it. I'm not sure how that's going to happen, as I have zero skills there.
