1Step 1
The MagicShifter3000 comes fully assembled, but there is also a DIY edition available if you want to print your own case.
You can download the .stl files for the 3D-printable case and the lasercuttable inlay here -
2Step 2
The complete software is open source.
MagicShifter 3000 comes fully flashed and preprogrammed, but you CAN change everything.
Check out the software in our github repo here:
jascha ehrenreich
