I used LTSpice last night to do some circuit simulation. I hooked up the SiTech controller to the scope and found it uses a 23.45khz base frequency. Popping this info into LTSpice allowed me to come up with a pretty simple 2 pole low pass filter that should give me reasonable ripple and good step response with a 10v max output.
Jerry Biehler
