I got the declination fine adjuster installed last night. It came out of an old Sperry Gyroscope Tool Set I got a couple years ago. A little overkill but it should work fine. I also made up the clamps for the Dec adjuster as well.
Next is the dovetail saddle for the scope and the mechanical portion of the scope will be done. I need to start ordering some parts for the control system, a couple AM26LS31 line drivers for the step/direction inputs of the servo drives and the bluetooth module for the controller. A guy at the local Dorkbot meeting gave me one of the Orbital LK204 serial LCD/button modules. I might try to use it as a control pendant.
http://www.matrixorbital.com/product_info.php?products_id=207
The adjuster, should barely clear the scope, it came out bulkier than I had hoped:
The kit the parts came out of. I had just bought it for the case but figured the rest might come in handy someday.
Jerry Biehler
