PiZero Synchronized Sound Distribution
Multi-device streaming sound synchronization for home/apt.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Chromecast Audio now allows multi-device sound synchronization. But you may have other existing streaming audio devices throughout your home/apt. Adding an inexpensive Raspberry Pi Zero (with USB audio) to each will bring them all into stream synchronization. The PiZero will add a delay buffer whose pointers are adjusted to advance/retard delay to bring everything into sync. Written in C. Uses the PortAudio library.
