Release samples ready
A project log for ELLO 2M
The DIY laptop built entirely from PCB
KnivDKnivD 11/06/2016 at 11:153 Comments
The first three fully manufactured samples are on their way to me from the factory.
To make everyone's life easier I have also added in the kit a small screwdriver and two self-adhesive pads to keep the LCD panel and the battery securely in place. Obviously a pack of screws and standoffs as well. The battery now is wired with a small 2-pin connector, so it won't be needed to be soldered making it easier for assembly by users with no soldering equipment or abilities.
Once I verify and confirm these three systems (will probably publish a new YouTube video soon), people will start receiving their ELLO 2M systems.
Maybe should put together a one-page printed instruction for assembly to be included in the box as well... Ugh.
Dirk Wouters wrote 11/07/2016 at 17:35 point
Great Work!!!
Are there any news about the "Hacker" Versions?
KnivD wrote 11/07/2016 at 19:21 point
Soon will have an update about those as well
Yann Guidon / YGDES wrote 11/06/2016 at 11:50 point
FABULOUS !
