Current Code
A project log for Coil Gun/Gaus Cannon
A device that uses electricity to propel a projectile at a significant speed.
jeff.ballard.86jeff.ballard.86 04/29/2014 at 16:330 Comments
Now if you are looking at this remember I am a code noob, constructive criticism is highly encouraged.
Code:
#include <LiquidCrystal.h>
#include <EEPROM.h>
//variables
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
float time = 0;
unsigned long StartTime = 0;
unsigned long StopTime = 0;
float timer;
float gateD = 3.6; //distance between gates in inches
float gate = 0;
float fps = 0;
float seconds = 0;
int FireDelay; //second SCR fire Delay
int FireDelaySave = 0;
float Debounce = 50; //button debounce time
//pin states
int UpButtonState;
int DownButtonState;
int FireState;
int SaveButtonState;
int FireButtonState;
//pin labeling
const int Up = 30;
const int Down = 32;
const int Save = 36;
const int FireOne = 9;
const int FireTwo = 8;
const int FireButton = 31;
const int SecondCoilGate = 38;
const int SpeedTrapOne = 48;
const int SpeedTrapTwo = 50;
//EEPROM saving variables
int FireDelayAddress = 1;
int FireDelayMultiplierAddress = 2;
int FireDelayMultiplier;
void setup()
Serial.begin(9600);
lcd.begin(16, 2);
pinMode(FireTwo, OUTPUT); //Second SCR fire mosfet
pinMode(FireOne, OUTPUT); //First SCR fire mosfet
//digitalWrite(FireOne, HIGH);
//digitalWrite(FireTwo, LOW);
FireDelay = EEPROM.read(FireDelayAddress); //read FireDelay from eeprom
FireDelayMultiplier = EEPROM.read(FireDelayMultiplierAddress); //read multiplier from eeprom
if (FireDelayMultiplier != 1 | FireDelayMultiplier != 2 | FireDelayMultiplier != 3){ //1st boot up sequence if mulitiplier is not equal to 1,2, or 3, set to 1 and set default fire delay
FireDelayMultiplier = 1;
FireDelay = 500;}
if (FireDelayMultiplier == 1){
FireDelay = FireDelay;}
if (FireDelayMultiplier == 2){
FireDelay = FireDelay * 10;}
if (FireDelayMultiplier == 3){
FireDelay = ((FireDelay * 2)*10);}
void loop()
digitalWrite(FireOne, LOW);
if (digitalRead(Up) != UpButtonState) //Up Button Code
UpButtonState = digitalRead(Up);
if (UpButtonState == HIGH)
FireDelay = FireDelay + 20;
lcd.clear();
lcd.setCursor(0,1);
lcd.print("Fire Delay");
lcd.setCursor(11,1);
lcd.print(FireDelay);
lcd.setCursor(14,1);
lcd.print("uS");
delay(Debounce);
if (digitalRead(Down) != DownButtonState) //Down Button Code
DownButtonState = digitalRead(Down);
if (DownButtonState == HIGH)
FireDelay = FireDelay - 20;
if (FireDelay < 0) {
FireDelay = 0;
lcd.clear();
lcd.setCursor(0,1);
lcd.print("uS");
delay(Debounce);
if (digitalRead(Save) != SaveButtonState) //save Button Code
SaveButtonState = digitalRead(Save);
if (SaveButtonState == HIGH)
if (FireDelay < 260) {
FireDelaySave = FireDelay;
if (FireDelay <= 2500 && FireDelay >= 260) {
FireDelayMultiplier = 2;
FireDelaySave = FireDelay / 10;
if (FireDelay <= 5000 && FireDelay > 2500) {
FireDelayMultiplier = 3;
FireDelaySave = ((FireDelay/10)/2);
EEPROM.write(FireDelayAddress, FireDelaySave);
EEPROM.write(FireDelayMultiplierAddress, FireDelayMultiplier);
delay(100);
lcd.clear();
lcd.setCursor(0,1);
lcd.print("Saved");
delay(1500);
lcd.clear();
lcd.setCursor(0,1);
lcd.print("uS");
if (digitalRead(FireButton) != FireButtonState) //Fire Sequence
FireButtonState = digitalRead(FireButton);
if (FireButtonState == HIGH)
//delay(Debounce);
digitalWrite(FireOne, HIGH); //fire first SCR
while (digitalRead(SecondCoilGate) == LOW) {
} //wait until projectile trips gate
StartTime = micros(); //FPS measurment start
digitalWrite(FireOne, LOW); //turn first SCR off
delayMicroseconds(FireDelay); //delay until projectile is in the perfect spot
digitalWrite(FireTwo, HIGH); //Fire Second SCR
delay(1); //delay to give secoond scr to start up
digitalWrite(FireTwo, LOW); //turn second SCR off
while(digitalRead(SpeedTrapTwo) == LOW) {
} //First sensor was tripped, now wait for second sensor to trip
StopTime = micros(); //second part of FPS measurment
time = StopTime - StartTime; //time elapsed between gates
seconds = time / 1000000; //find feet per second, math
gate = gateD / 12;
fps = gate / seconds;
//Serial.println(time);
//Serial.println(seconds);
//Serial.println(fps);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Feet Per Second");
lcd.setCursor(0,1);
lcd.print(fps);
//delay(1000);
