Ballistic Stabilization
A project log for Coil Gun/Gaus Cannon
A device that uses electricity to propel a projectile at a significant speed.
jeff.ballard.86jeff.ballard.86 05/06/2014 at 20:535 Comments
So I trimmed out my back door today, and then decided to make something for my coil gun.
I purchased some .5 id .625 od poly-carbonate tubing a while back, along with a little 6v motor.  So I 3d printed a motor mount and a magnet mount (attaches a magnet to the end of the motor shaft.)
The motor mount has a hole that I will thread with a 8-32 tap and it will except a threaded rod to be used as repositional stop so I can test projectile placement in relation to the coil.
The projectile will attach to the magnet, the motor/projectile assembly will then slide into the barrel, motor will spin up, coil gun will fire, and hopefully will have a stable ballistic path.
I also printed out some new coil endcaps that will also be used as my new photo gates.  I expect to push nearly 4000 amps through each of the new coils, I am also hoping to reach projectile speeds in excess of 500 feet per second.
jeff.ballard.86 wrote 05/22/2014 at 14:54 point
Im just using multiple online projectile energy calculators, they all give me the same number.
dave.m.mcdonough wrote 05/07/2014 at 23:09 point
Interesting idea.. and that's quite a bit of speed! How much does that projectile weigh?
Has accuracy been an issue? Some before/after data sets are definitely in order for this mod. :)
dave.m.mcdonough wrote 05/07/2014 at 23:26 point
You said output of ~80J so I think just under 7g to be at 500fps? The bearings I'm calculating mine with are 8.402g, so at 80J output it would be around 450fps (81.4J 139m/s). Asuming I didn't mess up my spreadsheet somewhere..
jeff.ballard.86 wrote 05/21/2014 at 17:48 point
My projectile weight is just over 30g. It is .5" diameter steel rod @ 1.25" length.
Accuracy for my projectile has been horrible, in some cases the projectile would hit the target sideways. you may not have to worry about this with your cylindrical projectiles.
dave.m.mcdonough wrote 05/22/2014 at 12:23 point
30g? man. I hope my equations aren't fubar, my numbers coming out of the spreadsheet are much different. I'll have to review things.
