• 1
    Step 1
    1/2" nylon ball-bearing that I drilled and tapped a 6-32 thread into 3/8" deep.
    These ball-bearings came from a wonderful place. Here is the link to the site.
    http://myworld.ebay.ca/toolsupply/
    This nylon plug made an excellent holder and allowed the drill hole to be centred.
  • 2
    Step 2
    With a round chainsaw file I cut a grove into the nylon ball. Then using J-B weld and the 6-32 screw I attached the ball-bearing to the Fibreglass shafts. The spring mounts were attached by 4- 4-40 set screws 1/2" in length. The set screws touch, this locked them in place.
  • 3
    Step 3
    The end effector socket mounted.
    The elbow joint mounted.
