關閉
Design Improvements
一個 project log 因為 NESPi Controller
Raspberry Pi Zero-based emulator in an NES controller case. Powered by LiPo battery and Adafruit Boost Charger.
kevin-neubauerKevin Neubauer 02/21/2016 at 20:230 Comments
  1. Filleting around corners
  2. Larger HDMI hole so it doesn't pull out as easy
  3. Pi Zero pulled further back into case. Only SD card is exposed now. Previous version had a part of the Pi Zero board exposed.
I will be moving the files to Thingiverse. However, it won't let me publish for 24 hours after creating a new account. In the mean time I've attached the files to this project.
討論
