close-circle
The flux compensator
A project log for blinking things
this is a rebranded project, sorry guys. take your skulls/likes back if you want :)
davedarko 10/13/2016 at 04:355 Comments
Please. I know. It's flux capacitor. But that might happen to every german-syncronized-movie-watching person. Maybe it's because of the drawing that says "flux compression". I still want to know what happened there.
Parts are all 1206 and super easy to solder.
Version 1
Version 1 - Rev 1
Version 1 - Rev 2 - final
I've updated the design to also have a battery holder and a switch (yay), also soldering points for a clip. Checkout #FLUX capacitor trinket for future updates :) ALSO: there's a four led, more resistors version by @Bastiaan - #Mini flux capacitor prop PCB
Order from OSH Park
int outer = 0;
int center = 1;
int inner = 2;
int pwmValue = 22;
int timeLength = 250;
int delayValue = 10;
void setup() {
  // put your setup code here, to run once:
  pinMode(outer, OUTPUT);
  pinMode(center, OUTPUT);
  pinMode(inner,  OUTPUT);
void loop() {
  // put your main code here, to run repeatedly:
    softPWM (outer);
    softPWM (center);
    softPWM (inner);
    delay(timeLength);
void softPWM (int pin)
  for (int j=0; j<timeLength/delayValue; j++)
    for (int i=0; i<pwmValue; i++)
      digitalWrite(pin, HIGH);
      delayMicroseconds(delayValue);
    for (int i=pwmValue; i<=255; i++)
      digitalWrite(pin, LOW);
Adam Haile wrote 06/19/2017 at 14:36 point
You have a BOM handy? I have to build this :)
davedarko wrote 06/19/2017 at 15:26 point
attiny13 or attiny45/85
9 x 1206 white LEDs,
3 x 0805 150 Ohm resistors
one of those (http://www.ebay.de/itm/192210025785)
and one of those (http://www.ebay.de/itm/291398146523)
I think that's all :D
Frank Buss wrote 06/16/2017 at 06:03 point
It was a mistranslation for the German version:
http://backtothefuture.wikia.com/wiki/Flux_capacitor
I guess the translators are not engineers :-)
davedarko wrote 06/16/2017 at 06:09 point
I guess I lived too long with automatic translations and google and dict.cc :D
Joel Nicklasson wrote 10/20/2016 at 16:09 point
Very nice
