Here're some thoughts on R-Pi peripherals which could potentially be used to generate a steady high-speed clock-output...
https://hackaday.io/project/10119-sdramthingzero-133mss-32-bit-logic-analyzer/log/34149-potential-pi-sdram-clock-sources(Note the R-Pi's peripheral data-sheet: https://www.raspberrypi.org/wp-content/uploads/2012/02/BCM2835-ARM-Peripherals.pdf Not sure which particular Pi Revisions this is applicable to...)
Eric Hertz
