Peripherals for clock-generation
A project log for Operation: Try to Bare-Metal the Pi
OMG you can "bare-metal" Pi's??? What to do...?
eric-hertzEric Hertz 03/20/2016 at 10:120 Comments
Here're some thoughts on R-Pi peripherals which could potentially be used to generate a steady high-speed clock-output...
https://hackaday.io/project/10119-sdramthingzero-133mss-32-bit-logic-analyzer/log/34149-potential-pi-sdram-clock-sources
(Note the R-Pi's peripheral data-sheet: https://www.raspberrypi.org/wp-content/uploads/2012/02/BCM2835-ARM-Peripherals.pdf Not sure which particular Pi Revisions this is applicable to...)
