changed assembly method
A project log for Super low cost VGA output for the Pi Zero
Similar to the vga666 board, but re-designed for the Pi Zero.
mincepimincepi 02/27/2016 at 23:350 Comments
Changed assembly method: It should be easier now. Also, since hot glue isn't used any more solder joints should be more reliable.
