• 1
    Step 1
    The first thing you should do is solder 2 wires to the 3rd and 4rth pin on the power boost 1000c
  • 2
    Step 2
    Second step: the second thing you should do is solder 2 wires to the power and ground pin on the power boost
  • 3
    Step 3
    Third step: solder the ends of the wires you just soldered to the power boost to the power pins on the pi zero
