Picking up the project from the dust
10/13/2020 at 08:21 • 0 commentsHi everyone,
After many years of postponing I finaly decided to build the version 2 on the Rpi. For now you can track my progres in the "1 Meter of Pi" contest. After the contest closes I will update this project.
Thanks for your patience
Aquaponic Controller on rpi zero
08/04/2016 at 09:58 • 0 commentsJust to keep you updated, I'm working on moving the project to rpi zero that will significantly lower the cost of this project. And adding some new features like db logging and ph, humidity, water temperature monitoring.
Davor
