This is the first prototype version, but still here's the source code if you are interested in how it's done:
#include <Servo.h>
Servo servos[2];
void move(int position) {
static int current = -1;
if (position == current) {
return;
current = position;
servos[0].attach(9); // right
servos[1].attach(10); // left
switch (position) {
case 0:
// Perk up.
servos[0].writeMicroseconds(1500 + 300);
servos[1].writeMicroseconds(1500 - 300);
Serial.println("perk");
break;
case 1:
// Droop down
servos[0].writeMicroseconds(1500 - 300);
servos[1].writeMicroseconds(1500 + 300);
Serial.println("droop");
break;
case 2:
Serial.println("left");
break;
case 3:
Serial.println("right");
break;
default:
Serial.println("unknown");
void rest() {
servos[0].detach();
servos[1].detach();
void setup() {
Serial.begin(115200);
move(0);
void loop() {
int z = analogRead(A0) - 490;
int y = analogRead(A1) - 490;
int x = analogRead(A2) - 490;
Serial.print(x);
Serial.print(", ");
Serial.print(y);
Serial.print(", ");
Serial.print(z);
Serial.println();
if (x > -10) {
if (y > 10) {
move(2);
} else if (y < -10) {
move(3);
} else {
move(0);
} else {
move(1);
delay(600);
rest();
deʃhipu
