Setting Up My ESP8266 Development Environment
A project log for ESP8266-01 Carrier
Arduino-ish clone (ATMega32U4) with interface to ESP8266-01
thomas-snowThomas Snow 02/20/2016 at 21:420 Comments
So I decided to bite the bullet and develop my framework directly onto the ESP. However, I didn't want to develop it on Linux, which seems to be the standard fare out there. I develop my Arduino/Atmel code using Eclipse on my Windows PC and I like the environment. I found a site out there that documents how to do ESP development via Eclipse.
If that's how you want to roll, here's the link.
Using a USB FTDI Serial cable (at 3.3v Tx & Rx lines) and a little breadboard with a 3.3v regulator (the signals from the cable are 3.3v, but annoyingly the power is 5v), and reset and program switch, I'm able to deliver my code right to the ESP chip.
So I rewrote the Framework to work directly off the ESP. And it works great. I had some challenges. The documentation regarding the ESP is scant and not well organized. I mean you can find the manuals for the API, but it doesn't document the ports, how to set them up, or anything about how memory is organized.
Here's what I learned/figured out:
I am still working on the code, but I am maintaining it on GitHub here. The GitHub will only have code that somewhat works. As I add stuff, I'll commit it and post a log.
