V2 Built
A project log for StickScope
Microscope holder add-in for StickVise
sufSUF 02/27/2016 at 23:090 Comments
I was thinking about for a while, how to attach a microscope to the stickvise. It became handy to have a microscope while soldering tiny SMD parts.
After a few weeks of thinking, tweaking, finally I developed a working prototype.
This is the second version. The first one had a monolithic cross section block, what used to much plastic, wasn't easily printable, and hard to handle.
After I assembled this model just realized a major design flaw. The microscope can't be positioned close to the bar of the stickvise where it is mounted. So I decided to tweak it a bit, so a newer version (v3) will come shortly.
