New Installation Script
A project log for IotPOS a Point of Sale for Raspberry Pi
Build your own DIY Point of Sale using a Raspberry Pi ZERO​/a+/b/b+/2 with a mini thermal receipt printer and IoT funtions.
hiram-villarrealHiram Villarreal 08/08/2018 at 23:390 Comments
Just copy and paste the following lines into a terminal:
git clone https://www.github.com/hiramvillarreal/iotpos
cd iotpos
sudo chmod +x install.sh
sudo ./install.sh
To start using the point of sale, in terminal type:
  iotpos
     * The default and only user and password is (without quotation marks):
     username: "admin"
     password: "linux"
To start using the administration module, in terminal type:
  iotstock
After reboot you can find the apps inside start menu>others
For an easy first time use, all security settings are disabled.
