After a lot of laser cutting, I test fit all of the outer case. The T-Bolt construction worked really well, as long as I was able to hold the nut in place.
A project log for Networked Low Resolution DMD Projectors
WiFi networked electro-mechanical 7x7 pixel flip-dot displays as giant DMDs (Digital Micromirror Devices) for low resolution projection
