BYOBeamer Event
A project log for Networked Low Resolution DMD Projectors
WiFi networked electro-mechanical 7x7 pixel flip-dot displays as giant DMDs (Digital Micromirror Devices) for low resolution projection
michael-shaubMichael Shaub 05/01/2016 at 21:170 Comments
I had the opportunity to setup 2 of the projectors at an art event called BYOB(beamer) and join quite a few other artists showing active and interactive projected projects. The projectors I built received a lot of attention, being the only unconventional projectors and installed in an entry point where they were able to utilize a narrow corridor with quite a bit of ambient light.
See below for some images and video from the event
