lambdaCPU v4.circProcessor file, requires installation of logism to work.- 412.75 kB - 07/10/2016 at 03:54 |
lambdaCPU instructionset.xlsxI used this to design the instruction decoder, useful if you want to write codesheet - 10.28 kB - 02/21/2016 at 21:34 |
lambdaCPU code.txtNotes for code (for reference only, may have errors, so if you want to run one of the programs, load it from the looptest.txt or hilotest.txt files)plain - 1.32 kB - 02/21/2016 at 21:18 |
lambdaCPU looptest.txtCode that tests the branch prediction (only backwards); right click on ROM labeled "program" in logisim, select load image, and choose this file to run the program.To change value that code counts to, change the lower two bytes of the first instruction to the desired value. plain - 52.00 bytes - 02/21/2016 at 21:16 |
lambdaCPU hilotest.txtCode that tests the accumulator registers; right click on ROM labeled "program" in logisim, select load image, and choose this file to run the program.plain - 102.00 bytes - 02/21/2016 at 21:15 |
lambdaCPU v3.circOld version, branch prediction/execution does not work properly because of forwarding. Processor file, requires installation of logism to workcirc - 414.98 kB - 02/21/2016 at 21:37 |
