Extending Motioneyeos with servos and on-screen display
A project log for "Solar Pi Platter"
A Li-Ion charger for Solar or USB with PMIC/RTC, 5V boost converter and USB Hub that can run Linux for only $5 more!
Dan JulioDan Julio 10/21/2019 at 21:590 Comments
This is a project I've wanted to do for a long time and finally found some time.  Calin Crisan's motioneyeos is a complete Linux distribution that turns SBCs like the Raspberry Pi Zero into complete web cams.  *AND* it's extensible.
 The Pi Platter's USB UPS functionality is perfect for making a webcam that has built-in battery backup.  Pan/Tilt servos and an on-screen power status display can easily be added by including the talkpp utility program and five simple bash scripts in a motioneyeos system.
Complete instructions can be found on the github if anyone wants to make their own.
