Board Up and Running
A project log for "Solar Pi Platter"
A Li-Ion charger for Solar or USB with PMIC/RTC, 5V boost converter and USB Hub that can run Linux for only $5 more!
Dan Julio 04/07/2016 at 19:120 Comments
Board is up and running with a significant amount of testing done. Still need to do full load testing and some signal quality analysis as well as fully test the firmware but it has run in a variety of configurations. So far the only additional change is to add a 22 uF cap.
