Pi V1.3 test pad dimensions
A project log for "Solar Pi Platter"
A Li-Ion charger for Solar or USB with PMIC/RTC, 5V boost converter and USB Hub that can run Linux for only $5 more!
Dan Julio 06/30/2016 at 17:510 Comments
Here are my measurements for the new V1.3 Pi Zero power and USB test pads. I'd love it if anyone else could verify or correct. I also think I made a small error with the vertical dimension for PP22 and PP23 (although we never saw a problem with the original 5 prototype boards).
