Rev 2 PCB Alive
A project log for "Solar Pi Platter"
A Li-Ion charger for Solar or USB with PMIC/RTC, 5V boost converter and USB Hub that can run Linux for only $5 more!
dan-julioDan Julio 09/20/2016 at 02:000 Comments
The second revision of the PCB is back and one unit built. Although there is still a bunch of testing to do it's alive. So far I have found a swapped set of transistor silkscreen part number labels.
Here's the board with a Pi Zero 1.3 booted from the HDD.
The new revision.
