PCB Revision 2 Preview
A project log for SamplerBox 1
Raspberry Pi Based Hardware Sampler / Synth Platform
P. T.P. T. 02/26/2017 at 10:362 Comments
Following testing of the initial prototype, new revision of the SamplerBox PCB is getting ready for manufacture. The dimensions were reviewed to reduce size of the board and also to locate audio connectors and controls on the back of the device.
Large balanced TRS jacks have been replaced with minijack to make the SamplerBox more miniature. The circuitry is designed to allow connecting SamplerBox to either unbalanced or balanced inputs using a special balanced cable, which offers same level of noise protection as TRS jacks.
stamenkovic21.zs wrote 11/23/2019 at 09:40 point
Für den Fall, dass Sie nicht mehr weiterkommen möchten
tedysuwarnadysoleh wrote 09/22/2018 at 03:00 point
do you have pcb layout file doc altium
files
