As a student myself, I think some music players can be hard to afford. Especially the ones small and compact, the price is usually pretty high ---- take iPod as an example, it cost $149. Which is overpriced. This project lets you build an MP3 player/Camera that cost way less than that.
I got my inspiration from looking at my old bulky music player, which doesn't have a graphical user interface either. The MPi3 will be a LOT smaller! And it also contains a camera as a bonus.
This is also a very good project to make if you want a portable device that you bring to school or work. Theoretically, it shouldn't take too much power too drive.
"Innovated" all by myself, "designed" all by myself.
Materials needed:
Raspberry Pi zero
Micro SD card greater than 4gb
16x2 LCD character display
PowerBoost 1000C (recommended) or 500C
2600 mAh LiPo battery (recommended size)
Micro (Mini?) HDMI extension cable/Adapter
USB to TTL Console cable
Micro USB to USB OTG cable
USB Hub (3 or more ports)
Ethernet adapter and/or mini WiFi dongle
USB webcam (Linux supported ones)
Micro USB charging cable x2
Soldering iron & related tools
Tactile Switches x5
USB storage device (low power consumption recommended)
3.5mm (1/8) Audio Jack
Capacitors
Resistors
Wires
Experimental use materials:
Breadboard
Jumper wires
Raspberry Pi 2 Cobbler
GPIO headers 2x20
