Beginning of Architecture Construction
A project log for 8-Bit Portable Internet-Enabled Computer
A portable computer based on the MOS 6502 that aims to enhance security and privacy.
blair-vidakovichBlair Vidakovich 04/07/2018 at 07:045 Comments
Here's my firs couple of hours making a simple conceptual flowchart for the architecture of the 8-Bit Portable Computer.
I don't have the protection circuitry for the 74LS612 MMU finished, so I didn't want to go into a complete electrical schematic.
The things missing in this diagram are:
I anticipate that I may need a second 6522 ACIA in order to debug the system.
At the moment, most of the components for the computer are remaining very cheap, so I am hoping this may be able to be copied and built elsewhere.
Blair Vidakovich wrote 04/08/2018 at 01:40 point
It's a famous paged memory mapper! There is loads of information about it on 6502.org
See the datasheet here: http://pdf1.alldatasheet.com/datasheet-pdf/view/116938/TI/SN74LS612.html
And here are two different web pages giving information about it:
http://www.6502.org/users/andre/icapos/mmu65.html
http://www.6502.org/users/andre/hwinfo/ls610/index.html
Yann Guidon / YGDES wrote 04/08/2018 at 11:09 point
Thanks ! I have looked at Google and found some information.
I have never seen this chip in the wild...
Jean Pierre Le Rouzic wrote 04/07/2018 at 21:08 point
It looks similar to three 74ls189 where the address buses are multiplexed  onto four address bits of the CPU and the 12 data bits are used to provide the higher address bits from A12 to A23?
Yann Guidon / YGDES wrote 04/07/2018 at 17:32 point
74LS612 ? Does that exist ? I have never seen that before........
Blair Vidakovich wrote 04/07/2018 at 07:05 point
I think the ROM and the IO can be mapped in between the 74LS612 MMU and the RAM with some simple address logic circuitry
