Hackaday.io Hackaday.io
Sign up Log in
POV Display (Persistence of vision)
A POV display using a ATTiny2313 uC , a HC_06 Bluetooth Module and shift registers with few LEDs
foxmjayFoxmjay
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1k views
0 comments
42 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
1k
0
42
13
Team (1)
  • foxmjayFoxmjay
Join this project's team
hardware
ongoing project
POV Display
Related lists
projects
stuff
This project was created on 02/26/2016 and last updated 10 years ago.
Description
A fascinating project to try out , the outcome is really beautiful . The idea is to add the internet of things capabilities to the POV display , that's the reason for the HC_06 BT module , which will be getting all the data to display through an android App . for the time being the display shows the clock only .
Details
Components
  • 1 × ATTiny2313 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × HC_06 Bluetooth Module
  • 32 × SMD LED
  • 2 × 74HC595D shift register Logic ICs / Flip-Flops, Latches, Registers
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Display a graphic
Project Owner Contributor
Miro
kawikawi
Esp8266 based Internet connected tiny display driver for 128x64 OLED I2C Display that can show any data or information from the web
IOT Display
sayantan-palSAYANTAN PAL
i wanted to use a 480x480 RGB Display on MCU, without sacrifice all IO for just the Display.
my square helper - a fast SPI based Display
thorsten-jaegerThorsten Jaeger
Abusing the custom characters of the HD44780 chipset to display some 漢字
Kanji Clock on Alphanumeric LCD
danielDaniel
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "POV Display (Persistence of vision)", please tell us the reason.
Send message
Remove Member
