It ain't pretty but hey at least it's finally up on GITHub - here's a rundown:
- toyboxcontroller.ino : Toybox Controller C Source for Arduino UNO Compaitble
- MBTCPClient.jar : Toybox Serial/Bluetooth Bridge Java Binary
- toybridge.cfg : Bridge configuration file with example syntax
- rxtx* : Fizzed's mfz-rxtx serial ibrary (incl. Windows DLLs)
The Java source isn't included yet - I just have to clean it up a bit more first. Stay tuned, k.
If you're a Twitch streamer and you've got an Arduino Uno (ish) and a servo, this should be everything you need to get started.
Next up: Instructions on how to actually get started. ;)
Thanks for tuning in!
Die, Master Monkey!
