I use a lot of tools, from network equipment and purpose-built PCs to multitools and soldering irons, and some of these things are worth telling about - just so that anybody can repeat the steps I did to improve my equipment. The things described here may not be worth their own <a href="http://HaD.io" target="_blank">HaD.io</a> projects, but they sure do have a couple of interesting ideas.
Some time ago, I found an article about modding soldering stations for safety (in Russian)(Google Translate). The problem is hot air guns suddenly melting and setting themselves on fire, supposedly, because TRIACs that control them fail.
Here's a video of this phenomenon:
Here's one more:
First, an explanation on how most Chinese hot air guns work.
I sometimes go on an eBay bidding spree, trying to get items of <1-2$ price which I don't really need right now but might need later. The same was with a nice LED dimmer (which I'd never plan to buy!) I found and subsequently won:
This is how these look like. I threw it somewhere and forgot about it. I also have a really cheap rotary tool which looks like this (only black, this seems to be just a rebranded version): It has a barrel jack connector on a cord for 12V power. I don't have the current consumption figures, sorry. Anyway, I needed a speed control for it because of noise produced, necessity to sometimes operate more smoothly and thus slowly and the fact that my tool started to develop some bearing problems, and speed might be a factor which I might want to take into account when I'll get the same tool to replace this one. I remembered that I had this dimmer somewhere, found it (the most difficult part in all this, honestly) and disassembled it:
Sometimes I need to set up a little network infrastructure to connect a multitude of devices to a network. I also can't be picky about PSUs, as I can get either a barrel jack one or a simple USB socket from my computer. Also, I need something to power all those Raspberry Pi boards I sometimes need to experiment on, and given all the environmental constraints (that is, in some places where I work there aren't enough wall sockets) one USB port with enough power makes all the difference. With that in mind, I've took a 8-port network switch I've been using for ages and repurposed it a little.
Network switch in question needs 5V. In its first revision, I used a LM7805. However, this proved to be unviable because the thing would heat up a lot from 12V, even with a heatsink. So, I turned to one of those fake-LM2596 DC-DC modules eBay is offering, and they're pretty decent compared to linear regulators in terms of efficiency. That worked, and worked pretty well, but these regulators are capable of more and I wasn't tapping into that capability. So I added a USB port which could provide 5V at enough amps to charge/power things. The switch both has a USB cord tapped into the 5V line and a 5.5/2.5 barrel jack connection which is connected to the DC-DC Vin.
That's what I used on soldering my VGA Terminal dongle. The wire is very flexible so they can bend easily and stuff inside the confined space. The multicolour wires are handy for colour coding the signals.
Useful fact: LPT cables contain thin colored wires which are easy to solder. They're much thinner than usual prototyping wires (about thickness of 40-pin IDE cable wires), which is very good for routing protoboards and clutter-less projects. Also, they are dirt cheap nowadays on flea markets.
