R.Ian test unit running
A project log for R.Ian, simple and easy built robot for education
R.Ian is meant so be simple to build but have interesting capabilities useful for teaching programming
audrey-robinelAudrey Robinel 03/30/2016 at 05:450 Comments
As i said in a previous log, the robot has been tested by students for two lessons, and it worked.
However, i never took the time to shoot a video about it. Now it's done :
The video isn't that great because OpenShot was not functionnal on my station, neither was KdeEnlive (i'll install a clean Debian soon in place of my OpenSuse that works but has some bugs now and then).
It's programmed with a simple obstacle avoidance algorithm, and it ran not so bad. Of course, there is a huge amount of room for optimization, but this was just a test program i made in 2 minutes.
I need to change a few things on the board, such as the power switch position (currently, the motors run when USB is plugged).
See you in the next log :)
