Serial-Dev-1A.zipEagle design files, top and bottom images w/ labelingZip Archive - 296.67 kB - 09/17/2016 at 11:02 |
FT_PROG template.xmlsince the FT2232H has a configuration EEPROM attached, these settings can be written with the FT_PROG tool to initialize the USB device and set all values accordingly.Since it targets mainly non-UART applications, the VCP drivers are deactivated. This can be changed back easily with FT_PROG. XML - Extensible Markup Language - 4.29 kB - 02/27/2016 at 21:12 |
