Hackaday.io Hackaday.io
Sign up Log in
MeArm Adventures
I got a MeArm, let's see what we can do with it.
danielDaniel
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.2k views
0 comments
1.1k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
1.2k
0
1.1k
13
Team (1)
  • danielDaniel
Join this project's team
hardware
ongoing project
mearm ROBOT Robotics arm Inverse kinematics servo arduino 2
Related lists
Favorites
List of favorite projects
This project was created on 02/27/2016 and last updated 10 years ago.
Description
Using the MeArm!
Project Logs
Collapse
  • Some more work envelope and constraint analysis
    Daniel • 02/28/2016 at 17:41 • 2 comments
  • Exploring the work envelope
    Daniel • 02/27/2016 at 19:06 • 0 comments
  • PCB and Cabling
    Daniel • 02/27/2016 at 18:50 • 0 comments
    I made a quick & dirty PCB to hold the Arduino Pro Mini that will be powering the arm (for now). Servo headers and power pins for the motors. I will expand this later on...
    I joined the cables going to the arm to avoid tangles and to make it look a bit neater. Tiny zip ties keep everything in place.
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Breathing new life into a 22 year old robot toy
Project Owner Contributor
Retro Robot Restomod
ossumOssum
but more stuff in it, than @benchoffs design I took the liberty to take.
Porygon V2 - but not the evolution of Porygon
davedarkodavedarko
An Arduino controlled robotic arm with a USB microscope using the Arduino YUN and uFactory robotic arm.
Armed Microscope
j-khaJ. Kha
An easy to build spider robot kit.
Kubik M0
dehipudeʃhipu
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "MeArm Adventures", please tell us the reason.
Send message
Remove Member
