Modify the Router
A project log for Friendly Neighborhood Hotspot
Free Public WiFi! Free Public WiFi!
greg-kennedyGreg Kennedy 02/29/2016 at 03:480 Comments
Remove the existing antenna. The idea is to put on a jack so I can connect antennas myself. Since N type connectors seem to be the go-to these days, here's my fancy hack job.
The existing antenna line was removed and wired to the connector instead. Still needs to be bolted to the body after some plastic cutting.
