One left to be modeled
A project log for Open Robotics Eurobot
Open Source competition robot development. You will never be alone for your contest again!
newdrivenewdrive 03/30/2016 at 09:550 Comments
All of the wheelbase components are modeled except the structure that holds everything together. We decided to laser-cut it in acrylic plastic, using the less quantity possible to keep the cost down.
Acrylic is transparent, so the motor/gear/wheels system will be visible, for educational and checking purposes.
