Finished shell
A project log for Powerful Portable Speaker
with bluetooth
moritz-walterMoritz Walter 03/15/2016 at 12:364 Comments
Sanding and color coating results
As you can see, the printed and assembled shell is now nice and shiny. Since I didn't want to expose my DSLR to the extremely dirty and dusty work of sanding, filling, sanding again and color spray painting, you may be content with looking at the following images of the finished results.
Actually, I'm quite happy with it. I used only what I had in the workshop, leftover racing filler, leftover sparkling black spraypaint, leftover clear varnish. The spay filler really did it's job in filling up the glueing marks and smaller imperfections of the print.
Checking the fitting
I test wise inserted the USB charging and audio connectors.. everything seems to fit.
How to get there
It's not as tedious as it reads, but patience is key. Those are the steps to get there:
  1. Assembling of printed parts by glueing them together using plain acetone
  2. Filling small gaps from not perfectly aligning parts using acetone-ABS-solution
  3. Drying 24 hours
  4. Hand-sanding (no sanding block) the whole housing with a 100 grit sandpaper
  5. Filling larger imperfections using acetone-ABS-solution
  6. Drying 24 hours
  7. Hand-sanding again, especially the filled areas, 100 grit
  8. First layer of spray filler
  9. Drying 24 hours
  10. Second layer of spray filler
  11. Drying 24 hours
  12. Sanding the whole housing with a 400 grit to a "class A"
  13. Dry-wiping and cleaning of debris from sanding
  14. First layer of sparkling black spray paint
  15. Drying 12 hours
  16. Second layer of sparkling black spray paint
  17. Drying 12 hours
  18. First layer of spray clear varnish
  19. Drying 12 hours
  20. Second layer of spray clear varnish
Alex Rich wrote 03/15/2016 at 17:18 point
Awesome results.  You're right, on a smooth part this really isn't that difficult, I have done it before by just brushing a thick layer of epoxy all over, it sands away like butter.   Spray filler sounds even easier, good idea.  What type did you use out of curiosity?
Moritz Walter wrote 03/15/2016 at 17:41 point
Thanks! I used a can of bulk-ordered "Spraila *901", that's a very cheap one rather than a good one. Works well tough, sands super fine. It's nitro based, so bonding with ABS is insane.
Jan wrote 03/15/2016 at 16:59 point
Actually hard to decide if render or real. No seams visible even... Amazing work!!!
Moritz Walter wrote 03/15/2016 at 17:25 point
Thanks! Now that is the best compliment :)
