Most common method i use of powering this device is a power supply or device from Ubiquiti, given the beaglebone only uses 10/100 networking this leaves those extra pins on the rj45 connector to break out the usually 24v power into the cape using the Blue and Brown Wires
added design files here
hewball
Marcin Saj
mircemk
