Matador lite v1.1
A project log for Project RedMatador
Project RedMatador is the whole of an ever expanding IoT system currently being developed. The base of which is a wireless web server.
alexanderhineAlexander_hine 03/31/2016 at 02:110 Comments
With version 1.1 came the ability to write the encrypted text to file. View results.txt in this projects file section to see an example of some song lyrics ran through the algorithm. If you can decode this I would give you major props. Any hackers want to give it a try?
