DDS AWG using raspberry pi
Design of an arbitrary waveform generator using a raspberry pi as the backend
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This is to design an arbitrary waveform generator (AWG) using the direct digital synthesis (DDS) technique. The samples will be generated using a raspberry pi and output through its GPIO pins. The goal is to generate arbitrary signals atleast upto 1MHz.
