banana pi BPI-M2+ (BPI-M2 Plus) quad core SBC
Banana pi BPI-M2+ (BPI-M2 plus) quad core singel-board computer
http://www.banana-pi.org
Banana PI BPI-M2+ is the open source hardware platform,Banana PI BPI-M2+ is an quad core version of Banana Pi,it support WIFI on board. use Alliwnner H3 chip on board. and mini size only 65mm*5mm
Banana Pi BPI-M2+ series run Android,Debian linux,Ubuntu linux, Raspberry Pi image and others image. Banana PI PBI-M2 hardware: 1Ghz ARM7 quad-core processor, 1GB DDR3 SDRAM, 8G eMMC flash on board,and SDIO wifi module on board.+
Banana PI BPI-M2+ with Gigabit ethernet port, It can run with Android 4.4 smoothly. it can easily run with the game it support 1080P high definition video output and 4K support, the GPIO compatible with Raspberry Pi B+ and can support raspbian Image
Note: Banana Pi BPI-M2+ not support sata port, so you need use USB for hardisk
BPI-M2+ hardware interface:
BPI-M2+ Hardware spec:
online document on gitbook:
https://bananapi.gitbooks.io/bpi-m2-/content/
3D design:
gitbook online document:
https://www.gitbook.com/@bananapi/
Portable Network Graphics (PNG) - 57.67 kB - 05/14/2016 at 09:19
Preview
Download
View project log
