Math behind the serpentinoid movement
A project log for Dtto - Explorer Modular Robot
Modular self-reconfigurable robot, focused on all-terrain search and rescue operations using bio-inspired locomotion mechanisms
albertoAlberto 10/20/2016 at 18:070 Comments
Hello there!
Hoping to answer some questions, here you can find the mathematical equations describing the serpentinoid movement:
The studies by Hirose were the first ones on modelling the snake movement:
Hirose, Satoshi. Biologically Inspired Robots (Snake-like Locomotor and Manipulator.: Oxford Science Press, 1993.
You can also check this derived paper:
Simulation Study of Snake-like Robot’s Serpentine Locomotion Based on Recurdyn
; by Wang Nan, Pang Bo and Zhou Sha-Shahttp://maxwellsci.com/print/rjaset/v7-37-41.pdf)
And this documentation in Spanish by Juan González:
http://nbviewer.jupyter.org/github/Obijuan/My-Ipython-notebooks/blob/master/serpenoid-curve/Serpenoid-Curve-es.ipynb
(I will probably make a document with all the documentation I´ve used as soon as I can…)
Thanks!
