Do you wanna feed your pets from outdoor? I have made a feeding machine which can be controlled on the browser using smartphone.
Cut pipes and prepare the screw. I made a screw by using 3D printer. Then, connect screw to a motor. and put them into a box.
Connect servo motor to obniz.
io0: GND,
io1: VCC,
io2: signal
Then power up your obniz.
Write codes below and put food into the bottle. Food will come out from the pipe.
View all 4 instructions
Reuben Balik
Foxmjay
Conrad Gray
[SF] Pigeon Kicker -- AkA James Ryan
Yes, delete it Cancel
You are about to report the project "Feeding cat remotely using smartphone with obniz", please tell us the reason.
