updgfx_r0.kicad_pcbKiCad raw PCB design. This can be uploaded directly to OSHPark.x-kicad-pcb - 1.89 MB - 05/08/2024 at 01:52 |
updated_uPD7220_design.zipUpdated schematic, with all KiCad design files. This is a bit messed up due to the KiCad version change and transfer, but the PCB design should work fine as is. This fixes the connections to the color resistor networks, and fixes the oscillator.Zip Archive - 3.62 MB - 05/08/2024 at 01:51 |
updgfx_r0_updated.pdfUpdated schematic, provided in PDF format. This fixes the connections to the color resistor networks, and fixes the oscillator.Adobe Portable Document Format - 138.46 kB - 05/08/2024 at 01:50 |
video_timing_calculator.pyPython3 program to create valid VGA video timings for the uPD7220. Use it to generate values to plug into videoconf.hplain - 5.11 kB - 04/04/2019 at 06:05 |
uPD7220_card_ctrl.inoAn arduino sketch used to control my graphics card. Use it as example code, a test program, or as a base for your own driver!ino - 3.77 kB - 04/04/2019 at 06:04 |
videoconf.hVideo configuration settings for the uPD7220. Goes with uPD7220_card_ctrl.inoplain - 1.45 kB - 04/04/2019 at 06:04 |
graphics_card_design.zipATTENTION: Old design, broken/old files, for archives only.This design partially works. The output from the shift registers should be q3, but q0 is used instead (a mistake). Before using either be prepated to modify the PCB or fix the design. x-zip-compressed - 797.96 kB - 04/04/2019 at 05:30 |
uPD7220-uPD7220A_User_Manual_Dec85.pdfIn case this disappears from the rest of the InternetAdobe Portable Document Format - 3.54 MB - 04/04/2019 at 01:40 |
