The board has been designed with low power as a priority. Both hardware and firmware solutions are specifically tailored to support that.
Bare board deep sleep current
Averages at 34uA
Deep sleep current with GDEW0213T5D display
Averages at 41uA
WiFi/BLE-enabled low power e-paper display devboard
Averages at 34uA
Averages at 41uA
PaperWifi.pdfSchematicsAdobe Portable Document Format - 618.21 kB - 03/03/2023 at 13:06 |
Fully functional firmware supporting low power operation is provided and can be found in the github repository.
Since we are using deep sleep, all the action happens in the setup function, only few state bytes are kept in RTC memory that is retained between wakeups:
void setup() {
Serial.begin(9600);
Serial.println(String("Hello, is_first_run:") + is_first_run);
SensorsInit();
SensorsPowerOn();
SensorReadings new_readings = SensorsRead();
if (is_first_run) {
sensor_readings = new_readings;
SensorsPowerOff();
if (is_first_run || sensor_readings != new_readings) {
DisplayInit();
NetworkInit();
DisplayData(new_readings, is_wifi_connected);
Serial.println(String("is_wifi_configured:") + is_wifi_connected);
if (is_wifi_connected) {
MqttSetup();
MqttPublish(new_readings);
} else {
Serial.println("Wifi not connected");
is_first_run = false;
DeepSleep(DEEP_SLEEP_TIME);
WifiManager library is used to support WiFi credential provisioning.
GxEPD library is used to access the display.
Examples available:
ESP32C3 supporting components is basically just following ESP32C3 Family Hardware Design Guidelines. There's a footprint for 32kHz crystal, but since it's not supported in Arduino environment, also pins are broken out as GPIO.
So I have decided to add WiFi to my display. It will not compromise display part, but will make it a more versatile tool for my sensor experiments. Also it adds another dimension to the project - it can not only display sensor data, but also whatever data pulled from the net!
I have chosen ESP32C3 as the main micro-controller because of two reasons - it's low power and it's risc-v based - I wandered how good risc-v support is in the standard Arduino tool chain. Also ESP32C3 has in build USB-to-serial peripheral saving the need to design in USB-to-serial converter chip.
Unfortunately, 2450 batteries had to go as they couldn't support high current spikes during WiFi communication. Thus AA batteries had to come in. I hesitated a bit between AA and AAA, but opted for AA to have more juice, meaning more communication and more display updates.
I have chosen to use bare ESP32 chip and add printed 2.4GHz antenna to the PCB mainly to use this as an opportunity to learn something, also I didn't want to change the size of the PCB a lot and module is a bit bulky. I still have to go to RF lab to perform antenna measurements, I have just ordered bare PCBs with U.fl connector added for this specific task.
Sometimes having sensor data piped over RF to your database or to your console is not enough. Sometimes you want a big display displaying your numbers you could just throw a look at. Sometimes you want to package your sensor and a display to a person at industrial facility so they could quickly measure something without involving connectivity and computer.
Thus 2 years ago I started on a journey to design myself a display like that. The device had to be battery operated - wall plug devices are a thing of the past, so e-paper was an easy choice for the display technology - low power, high contrast, relatively high resolution.
I am not very good at mechanical design, so I wanted to piggyback on something that's available, thus I stumbled on electronic label enclosure kit available from GooDisplay
Check out the tutorial here: Getting started with MQTT
This repository contains everything you need to set up InfluxDB, Mosquitto, Telegraf and Grafana to collect and display your data. Everything is pre-configured and ready to go. Easy IoT data infrastructure setup via docker
please add mesh network for example BATMAN
and create a emergency network on wifi
